Rear Fog Light Repalcement
Old Dec 22, 2006 | 01:25 PM
Joeski's Avatar
Default RE: Rear Fog Light Repalcement
I thought of adding the passenger side rear fog to my 00 2.7T. Is that possible? Any thoughts?
OOOO
Old Dec 22, 2006 | 02:18 PM
CamoA6's Avatar
yes it is possible, there is an article in Audi world about it, there is a spot for it on the right side, you just need to run power, ground, and a light holster over to the other side, I recomend you do it, I have seen it on S/RS6 looks great.
Old Dec 22, 2006 | 02:24 PM
jwphillips2's Avatar
A4 B5 had the empty receptacle on the passenger side and wired it up, stuck in a bulb, and Voila!, one of the best deterrents to tailgaters evah!
Old Dec 22, 2006 | 03:04 PM
SouthboroAudiGuy's Avatar
While it CAN be done, that doesn't mean it should. Having only one makes it much less ambiguous (i.e., clearly a fog light and not somebody braking) and is the standard in Europe. Audi USA bowed to consumer confusion (whereas rear fogs are the rule in Europe, they are a novelty here) and added a second rear fog in 02 (prior to that, there was only one on the driver's side). The fact that a second one can easily be added is due to the fact that they had to accomodate right hand drive cars.
I've got just the one and wouldn't dream of adding the other.
Old Dec 22, 2006 | 03:14 PM
techbod's Avatar
fog lights if used properly don't confuse anyone its when some prat drives with them on for looks ( which is against the law in the UK ) so if used right they will save you in the fog and 2 are better than 1 in this situation
Old Dec 22, 2006 | 03:55 PM
prbayha's Avatar
I've seen a fewAUDI's around town tha have done this MOD and it looks cool, but it also looks like you are driving around with your foot on the brake. In fog, it would save you big, but where I live, we really have no worries. Another "To each his/her own" topic.
Old Dec 22, 2006 | 04:06 PM
techbod's Avatar
in the UK its not a mod and its not a legal requirement but more cars have it than not, most newer cars have a high line break light so you know which is the break lights but that's newer cars, what if your break lights didn't work and your fog light was on?? some one might think you have a break light out also rear fog lights are or should be brighter because of the reflector which is different to the break light
Old Dec 22, 2006 | 04:08 PM
  #18
techbod's Avatar
Default RE: Rear Fog Light Replacement
to be very visible in the FOG is the question
Old Jun 9, 2008 | 10:45 AM
  #19
Here in the colonies, bicycles and motorcycles are somehow invisible to drivers of automobiles and lorries (not the birds). You can't have too many brightass lights on your transportation vehicle in the fog or on sunny days. Someone will still fail to see you, laws and regulations to the contrary.
Old Jun 9, 2008 | 01:28 PM
  #20
wammy18's Avatar
Why in the world would you ever add a second fog light? I am not even going to put a reason because it is just stupid :-X When people can see your car (obviously not in the fog) and you have them on. You just have people thinking your 50 with your fog lights on Which I see commonly enough
