repeated clicking after turning blinker signal off
Old Feb 11, 2008 | 03:16 PM
sollyd25's Avatar
Default repeated clicking after turning blinker signal off
Anyone have a problem where after you signal and then shut the blinker off you still hear the blinker clicking in the dash somewhere? Does any one know what that is? Is there a way to fix it yourself or or is it best to take it to the dealership? Thanks.
Old Feb 11, 2008 | 04:12 PM
Jeffla's Avatar
Default RE: repeated clicking after turning blinker signal off
Probably the hazard relay going bad. Very common problem, don't know if your are experiencing the symptoms though.
Just a though.
Jeff
Old Feb 11, 2008 | 04:34 PM
sollyd25's Avatar
Know any sites that show you how to replace the switch yourself because audi is charging $350 to fix the problem?
Old Feb 11, 2008 | 09:35 PM
daroshi's Avatar
Buy a new "Hazard Switch" for a mere $22 http://www.genuineaudiparts.com/. Carefully pry off the woodgrain panel surrounding the hazard flasher switch (I used a paper clip and bent the end 1/4" over to hook behind the panel, just push it in the gap, turn it 90 degrees and pull, works great!), push in the tabs on the old switch & pull it out, disconnect the plug on the back of the switch. Should take 10 minutes (45 minutes with a beer break!)
Old Feb 12, 2008 | 03:23 PM
louiscolburn's Avatar
I was JUST about to post something regarding what I think is the same thing. After I disengage the turn signal, a strange "crackling" noise comes from the dash. Could this be the same problem, and will the posted fix-actions make this annoying problem go away?
Louie
Old Feb 13, 2008 | 08:14 PM
sollyd25's Avatar
Thanks Daroshi. That was a big help.
Old Feb 17, 2008 | 02:47 AM
Teutonic2.7T's Avatar
i had the same problem with my passat, but it turned out to be the stalk... solly, did switching the hazard work?
Old Mar 1, 2008 | 02:29 PM
sollyd25's Avatar
Haven't tried it yet . I am going to mess around with it today and see. I'll let you know if you haven't already tried it yourself. 3/1/08.
rr319
B8 Models
Feb 1, 2013 01:54 PM
gahndai
Jan 28, 2011 10:31 AM
fast euro
Jan 1, 2011 04:02 PM
kent11
Dec 24, 2008 10:58 AM
SAudi
Apr 12, 2007 02:21 PM
