repeated clicking after turning blinker signal off
Anyone have a problem where after you signal and then shut the blinker off you still hear the blinker clicking in the dash somewhere? Does any one know what that is? Is there a way to fix it yourself or or is it best to take it to the dealership? Thanks.
Buy a new "Hazard Switch" for a mere $22 http://www.genuineaudiparts.com/. Carefully pry off the woodgrain panel surrounding the hazard flasher switch (I used a paper clip and bent the end 1/4" over to hook behind the panel, just push it in the gap, turn it 90 degrees and pull, works great!), push in the tabs on the old switch & pull it out, disconnect the plug on the back of the switch. Should take 10 minutes (45 minutes with a beer break!)
I was JUST about to post something regarding what I think is the same thing. After I disengage the turn signal, a strange "crackling" noise comes from the dash. Could this be the same problem, and will the posted fix-actions make this annoying problem go away?
Louie
Louie
