Replace just ignition coils ???
2008 audi A6 3.2 quatrro with over 210K miles suddenly just started with LOUD ticking sound. Initially thought it was the timing chain tensioner that needed replacing.....BUT.
After adding some seafoam to nasty old oil, changing the oil......the engine started VERY roughly. In order to keep the car running you have to step on gas. Drove it this morning and NO power at all.
Got these codes this morning:
Audi Codes
PO300- random/multiple cylinder misfire
PO068-mass airflow sensor, throttle position sensor and the Manifold pressure (MAP) sensor.
P12A1- Fuel rail pressure sensor-signal low
P0346-camshaft position sensor A circuit range/performance (bank 2)
P0172- Fuel trim, bank1 system too rich
P0301-cylinder 1 misfire
P0302-cylinder 2 misfire
P0391-camshaft position sensor B circuit range/performance (bank 2 )
P0306- cylinder 6 misfire
P0305-cylinder 5 misfire
Should I just replace ALL the coils and clean air intakes or MAP?
Thank you in advance for any advice/help
Audi Codes
rhodesdf
Nov 7, 2007 04:52 PM
afruss2007
Feb 2, 2006 02:00 PM
