rotor help!
Old Oct 28, 2008 | 05:47 PM
TopGUn86's Avatar
Default rotor help!
i unbolted the caliper, now the rotor will move around but there is a thingy in the way and i cant fully remove it... how do i get the damn thing off??
Old Oct 28, 2008 | 09:18 PM
TwinTurboC5's Avatar
Default Rotor Help!
Are you working on the front or rear brakes?
Old Oct 28, 2008 | 09:23 PM
Default Rotor Help!
If its the rear rotors, that "Thingy" is a caliper mounting bracket. You can remove it by taking out the two bolts mounted on the back side of it that secure it to the wheel hub. I believe they are secured with two allen head bolts. Stick your head inside the wheel well and look on the backside of the "Thingy", and you should be able to see them (bolts).
Old Oct 29, 2008 | 08:01 AM
bob martin's Avatar
The bolts that hold the thingy on are loctited into place and are difficult to break loose. You SHOULD be able to get the rotor out without remonig the thingy. You have to tilt the rotor just so.....
Bob
saifxnyc
Oct 14, 2012 05:35 PM
Q7Barry
Audi Q7
Aug 15, 2012 11:13 PM
jwd2a
Jun 19, 2010 09:21 PM
MrTsB5A4
Feb 18, 2010 01:12 PM
james0013
Oct 7, 2008 12:23 PM
