Rotor replacement
Old Oct 6, 2008 | 11:38 AM
james0013's Avatar
Default Rotor replacement
Hi guys,
I think I may have worped the front rotors on my 2000 A6 2.7T, does anyone know where there is a DIY on how to change them? I can find the Audi world tech artical on pad replacement but it does not make any mention of rotor replacement.
Thanks
James
Old Oct 6, 2008 | 01:23 PM
madridlover's Avatar
if it's anything like the 2.8L it's easy. On my 2.8l the rotor just comes off...no srews or bolts. May need a mallet or hammer to knock it off though....and maybe some PB Blaster too.
Old Oct 6, 2008 | 02:16 PM
james0013's Avatar
NO NOTHING TO HOLD A ROTOR ON!!!!!!!!! that is the first I have ever heard of that. can someone confirm that for me please.
Many thanks
James
Old Oct 6, 2008 | 03:25 PM
That's how it was on my 2.8L. I had to use a hammer and spray PB Blaster for the driver's side because it was rusted on the axle.
Old Oct 6, 2008 | 05:27 PM
NH_USA's Avatar
Many - many - many vehicles don't have things to hold the rotor on.
A few have a single little spring clip on the studs -but that usually gets thrown away the first time they are changed. Vehicles that use lug bolts instead of lug nuts sometimes have flat head screws to hold the rotor so the bolt holes stay lined up and they can be a witch to get unscrewed - but I haven't seen them on Audi's.
As madridlover says - the rotor sometimes get stuck on the hub and it takes a BUNCH of persuasion to get them off. Mallet - Hammer - sledge hammer - bad language - PB Blaster - are all part of the fun! Once you start -you have to keep going because the rotor can get a bit messed up if it sticks to hard.
Old Oct 6, 2008 | 06:22 PM
afstud6900's Avatar
Banned
i have done all my rotors and brake pads myself and all i had to do was tap the rotor with a hammer and it came right off., its really simple and now i have all new stuff...
Old Oct 6, 2008 | 09:09 PM
TopGUn86's Avatar
i am replacing mine this weekend. my friend said i needed a special tool for the rotors... do i? is the special tool a hammer and maybe duct tape?
Old Oct 7, 2008 | 12:23 PM
NH_USA's Avatar
Get the really big hammer and extra extra wide duct tape. The only special tool you might need is the one to twist the rear calipers as you push them in. It can be done with a clamp and channel locks but you have to be vary careful.
tomplace
Audi Q5
Nov 9, 2011 11:24 AM
ToV
Oct 19, 2011 11:14 PM
kbunting
Jul 15, 2007 09:11 PM
dudley doright
Sep 2, 2004 01:39 AM
