Rotor recomendation
Old Jun 1, 2009 | 11:16 AM
james0013's Avatar
Default Rotor recomendation
OK so somehow I managed to warp the front rotors I dont know how but I did.
I wanted an opinion on putting slotted and drilled rotors on the front. I am aiming to aid in cooling and hopefully avoid warping the rotors again.
Do you think this would be effective or would I be wasting my hard earned Dollars?
Thanks
Old Jun 1, 2009 | 11:21 AM
hxgaser's Avatar
For street application, I really don't think slotted or drilled rotors are worth it. I always had good success with Brembo blank rotors. They are cheap and never had warping issues.
Old Jun 1, 2009 | 05:00 PM
ppgoal's Avatar
My indie shop replaced my rear rotors with Centrex and they seem to work fine. Nothing special, but I just drive high speed interstate and don't use brakes a lot. I would have used the same on the front but he was able to turn them (probably the one and only turn I'll get from the rotors). I broke them in gently and kept away from water the first week. Just my 2 cents.
Old Jun 1, 2009 | 11:41 PM
Jackmup's Avatar
If you warped them your driving habits may be harder than others. I would go with the perforated or slotted it will disperse the heat better, also check your rear brakes make sure the rotors are not to thin they may not be applying enough pressure to help the front. I had the problem on my suburban and I had to drill my rotors to stop it. It was caused by the crappy rear drums not applying pressure. but the perforated rotors solved the problem. Do you have a long comute/ heavy stop and go traffic? That will do it.
Old Jun 2, 2009 | 01:42 PM
formulagigi's Avatar
stick to regular rotors and get good pads and SS brake lines with race fluid. You'll be good. thsoe fancy rotors on our cars warp easily and yuo don't need to add to the possible cuases of vibrations on our cars..
mblayton
Aug 9, 2011 11:31 PM
rstray
Jun 6, 2011 06:17 PM
gu9cci
Dec 25, 2010 07:52 PM
stans4
Mar 29, 2008 09:13 AM
blue2.7turbo
Jun 4, 2005 01:37 PM
