Sponsored by:
Sponsored by:
Rough idle..
Old 02-15-2011, 08:41 PM
cwilliamsccn's Avatar
Default Rough idle..
Whats up all im new here, just picked up a 2000 a6 2.7 quattro ith 102k miles, the car was idling fine but under load it was bogging. I replaced the maf and cleared up the bogging under load but now I have a rough idle and throwing a p0300 random/multiple misfire code.. any ideas? plugs are new so is air filter and fuel filter.. any help would be great.
Old 02-16-2011, 12:40 AM
I should also mention I changed the battery, thats when the problems all started.
Old 02-16-2011, 12:52 AM
chefro's Avatar
the 0300 group is more likley related to spark plugs/coils.
(example: 0303 - means you need to check cylinder no 3)
- You need to check your igniton coils/wires
- and/or you may have to do a throttle recalibration (not sure if that's done/needed on a 2000 after batery disconnect)
** by the same token:
- your MAF sensor maybe just started acting up - clean it
- Idle Control Valve may need to be cleaned/replaced
Old 02-16-2011, 04:55 PM
Funny you say cylinder 3.. It threw a p0303 so I put I new coil pack, started it up no codes and idles great.. Started driving then it started bogging again then the idle got rough and back to random misfire codes.. I'm thinking a bad ICM ?
Old 02-17-2011, 12:16 AM
chefro's Avatar
It is entirely possible, of course, but I don't know if you can check it.
Fuel, spark, air - isn't that the triumvirate of proper operation?
Air: you replaced the air filter and cleaned the MAF (didn't notice that when I initially red your o.p.)
Spark: you replaced the plugs (are they the "right" ones?- these cars are finiky I think in terms of spark plugs) - proper torque?; you also replaced one coil...
I would say do a cheap investigation: get a spark checker ($ 7-8 at places like AZ, AA or O'Reillys) that plugs into the coil...that way you can check each coil and wire for appropriate electric arc
Since you said that the trouble started after replacing the battery, I wonder if you need to check your voltage regulator?!?
Fuel: you already replaced the filter. However, your last resort (after eliminating the first two categories) would probably be a fuel pressure check.
If anyone else can think of a more proper way to look at this, please chime in.
Old 02-17-2011, 01:17 PM
Well it gave me another cylinder 3 misfire after swaping coil.. this is what happened when the other icm wen't out.. I should have the new icm tomorrow hopefully that resolves it... should have just bought two last time.
Old 02-18-2011, 01:17 AM
FIXED! So I was running autolight double platinums.. Pulled one out and it was cracked and the rest had red soot.. Replaced them all with NGK iridium .32 gap.. Car runs great and pulls harder than I have ever felt it.
Old 02-18-2011, 02:14 AM
If anyone needs a ICM bosch 4A0 905 351 let me know since I already ordered it from the dealer and that wasn't the prob..
Old 02-18-2011, 07:21 PM
chefro's Avatar
Excellent job.
So the spark plugs were responsible for the mischief
You can still buy that plug arc tester; in the future you'll diagnose the problem much faster and easier.
jsweete
01-29-2016 08:42 AM
rekabj1108
04-19-2012 10:47 AM
justinclarke
11-25-2010 04:03 PM
Swami51
11-04-2008 05:08 PM
Quick Reply: Rough idle..
