RPM jumps, then car dies
Old Mar 17, 2009 | 03:09 PM
copper07's Avatar
Default RPM jumps, then car dies
98 A6 Q.
Issues -
The RPMs will jump between 1 and 3 several times then, the car will then drive rough, and die. If I try to restart the car it won't turn over. I tried starting the car the next day and it is fine. This is frustrating. Sometimes it takes several days before the car will run again.
I would like the car to be more reliable.
It has done this several times and the shop says they can't find the problem if the car is not having issues when I bring it in.
Any ideas what the issues could be or what to do to begin looking for the issue?
Old Mar 17, 2009 | 04:48 PM
NH_USA's Avatar
Check the ground cable between the frame and motor.
Don't just make sure it is tight.
Remove both ends - clean the surfaces and reinstall.
Old Mar 24, 2009 | 05:31 PM
copper07's Avatar
I will try that and see if the issue returns. Thanks for the idea.
dmthomas
Feb 14, 2013 01:12 AM
eradz
Mar 24, 2011 05:04 PM
haffy
Mar 18, 2008 01:20 PM
Notahondaowner
Feb 7, 2008 09:37 AM
miabhai_freaked
Jan 26, 2006 09:42 PM
