RS6 Tip different than A6 Tip?
Old Dec 24, 2007 | 08:20 PM
bsharp8's Avatar
Default RS6 Tip different than A6 Tip?
I was just curious if the Tiptronics were different in these two cars, as far as handling torque. I've read that the Tip in my 2.7t won't handle the extra power from a chip.
Thanks
Old Dec 25, 2007 | 12:21 AM
dankhound's Avatar
Default RE: RS6 Tip different than A6 Tip?
When you chip an engine you are supposed to chip the transmission as well to help increase the life of the transmission. I cant say for sure but i highly doubt the trans behind your 250hp 2.7 is the same trans that is behind the 450hp rs6.
Old Dec 25, 2007 | 09:17 AM
bsharp8's Avatar
I didn't think so. Thanks.
Old Dec 25, 2007 | 01:27 PM
csobel's Avatar
The tip will handle the power of a chip pretty easily. It's generally when it comes time for a ko4 swap that you would consider TC/valvebody upgrade or a full level 10 build.
Old Dec 25, 2007 | 05:43 PM
bsharp8's Avatar
Cool deal. Thank you also.
Old Dec 27, 2007 | 06:05 AM
Baskin 4.2l's Avatar
the A6 and RS6 trans share the same base but the trans it self is different tech gearing and parts. The RS6 trans has issues handling the power of the 4.2T but so far it seems that the 2.7T transmissions are in good shape...until the ko4 comes in
Old Dec 27, 2007 | 09:01 PM
bsharp8's Avatar
Thanks a bunch guys. I appreciate your input.
Old Dec 29, 2007 | 12:00 AM
cr!mz's Avatar
... that's why we go standard
