SEA FOAM.....marine & auto
Old Jun 4, 2009 | 07:33 PM
IDUA ORTTAUQ 6A's Avatar
Default SEA FOAM.....marine & auto
Anyone try it?
It's $10 buck and change from NAPA............I put a whole can in a 3/4 full tank and after 100 mi I realized my injectors were in fact clogged because I began getting way better acceleration and my fuel economy jumped up 5 mpg! Anyone else know what I'm talking about? Try it!
Old Jun 4, 2009 | 07:39 PM
gone postal's Avatar
From: Nation's oldest city, FL (screw you Jamestown)
Yeah, Sea Foam is great stuff - I've used it for years. You can also put it in your oil, but do it about 30 miles BEFORE you do an oil change - it breaks down the oil, so you don't want it in there for long. I've used it on my boat motor, lawn mower, last several cars, etc. They also make an aerosol spray called Deep Creep for the hard to reach areas (I spray it in my boat motor's spark plug holes to soak and break up the carbon once a year - it's a 2 stroke motor).
Old Jun 4, 2009 | 08:22 PM
Jerzyboy973's Avatar
I've used in in my oil before. Stuff seems to work great.
Old Jun 5, 2009 | 04:05 PM
ppgoal's Avatar
I've seen it for $8 at Autozone and $6+ at Walmart. I'm considering dumping a can in my gas tank but am a little concerned it may clog the fuel filter or injectors. I just had the fuel filter changed last year and don't want to do it again. Anyone ever have a bad experience adding it to the gas?
Old Jun 5, 2009 | 04:20 PM
Jackmup's Avatar
I have added it my gas a few times no problem it's so diluted in a tank of gas I can't see you having a problem.
$4.00 Northern Tool - smart shopper
Old Jun 5, 2009 | 07:03 PM
DÌEGØs AÜD!CTIØN's Avatar
yeah i've used it in the vac lines/gas tank a couple times and i havent had any prblems.
but its recomended that you change sparkplugs if you do it through the vac lines! which is the most effective way to do it IMO.... havent tried it in the crankcase...
Old Jun 10, 2009 | 01:28 PM
csh724's Avatar
Default How often
anyone have any ideas on how often this should be used?
CarsforourTroops
Aug 28, 2011 11:17 AM
CarsforourTroops
Aug 19, 2011 02:15 AM
sydmik08
Jan 11, 2010 02:46 PM
airguard350
Oct 29, 2008 06:00 AM
StepUpProductions
Feb 13, 2006 01:29 AM
