Secondary air pipe
Old Jul 31, 2009 | 01:19 PM
monsterrider's Avatar
Default Secondary air pipe
1998 with 2.8L 5V. Can anyone tell me or point me to a link that shows the location of the secondary air pipe. My dealer says mine is cracked and leading to a CEL.
OK found the pump and flexible tube from the pump to the steel/al? tube going under the manifold to the combi valves. The pumps runs for a couple minutes on start up, then stops as expected. The flexible tube warms up. I cannot see or feel any leaks in the flexible tube. Could the crack be in the fixed tube going to the combi valves? The dealer quoted a price of about $117 for the tube but didn't tell me which one?
Any thoughts?
I'd love to great rid of this CEL
Thanks
Old Aug 1, 2009 | 07:36 AM
bob martin's Avatar
Bob,
The secondary air pump tube also gets clogged. Maybe that is what he is talking about. In any case, $117 isn't too bad of a price. The job can be a PITA but, if you are very patient, it isn't too hard.
Bob
Old Aug 1, 2009 | 10:58 AM
The metal tube under the manifold looks pretty difficult to change without removing the manifold. From the pieces I can see (only a small section though) it looks fine.
The plastic corrugated hose from the pump to the metal hose looks OK but you say gets plugged? I bet the $117 the dealer quoted for the tube was that piece, based on what they wanted for a similar plastic tube connecting the two camshaft covers.
Can I pull the plastic hose and apart and if it cracks, which it might, can I replace with a piece of rubber hose with clamps at either end?
Thanks
Bob
hartsoe1
Jun 20, 2012 10:19 PM
mizzike2555
Apr 23, 2008 05:05 AM
Mythstery
Jan 19, 2006 08:17 PM
greenday
Nov 29, 2005 03:43 PM
