Seriously Major oil leak!
Old Nov 23, 2013 | 04:51 PM
soundguy's Avatar
Thanks for the replies..
ManyAudis,
What do you mean by "Most of the time it is the coolant that leaks?"
Old Nov 23, 2013 | 06:02 PM
ManyAudis's Avatar
The oil cooler has two coolant lines. Usually the point at which one of these lines connects to the cooler will leak and drip on the ground. See item 10 in the image.
Old Nov 24, 2013 | 04:09 AM
M5S5's Avatar
Tech Certified
That seal for the cooler is what goes bad. The cooler is the oil filter housing.
Old Nov 24, 2013 | 03:20 PM
soundguy's Avatar
Thanks.
Even if oil is coming out of this seal pretty rapidly the car should still start, shouldn't it?
Old Nov 25, 2013 | 02:47 AM
Nebuchadnezzar's Avatar
Oh... I can see where this is going.
In theory, yes... an engine should still start, but not for very long. If it isn't turning over and you lost a substantial and ran it with a small amount of oil then you might be in trouble.
Old Nov 25, 2013 | 09:37 AM
soundguy's Avatar
Well, I may be in trouble then.
I have already stated this earlier in the thread so I'll bullet point.
- Replaced both valve cover gaskets and passenger side cam tensioner seal
- Filled the oil and cranked teh car
- Car ran for 3 seconds
- Motor was knocking pretty bad
- I thought motor sounded like that because it had no oil and the cam tensioners did not get enough oil pressure to adjust
- Ran out of battery and couldn't start car again
- Car turns over smoothly and does not sound bad
- Charged battery and tried again
- Car almost starts
- Huge stream of oil coming from atop and around the oil cooler.
- Constant sad face now.
jba4229
Dec 14, 2013 07:48 PM
Deth2002
Jan 25, 2013 05:10 AM
cardiffkid
Jan 29, 2010 07:58 AM
dan104
Jul 12, 2008 08:11 PM
