Several Vag-Com questions
Old Aug 24, 2009 | 05:46 PM
xewax's Avatar
Member
Default Several Vag-Com questions
Hello.
I have several questions related Vag-Com.
Why adaptation channels 40-48 must be entered in determined order?
Thanks in advance
1 question - What is the best value here:
2 question - Is it possible to change something here?
3 question - what is the best value here?
4 question - Can you explain me this one?
5 question - What is stored here?
http://i28.photobucket.com/albums/c2.../60channel.jpg
6 question - Can you explain me about this?
7 question - What can I do with this?
8 question - What value is the best here?
Old Aug 24, 2009 | 06:19 PM
nm3210's Avatar
All of your questions regarding "what value is best here" can be answered easily: the current value is the 'best unless you're having problems and it needs to be calibrated differently this goes for #1, 3, & 8. I really want to give you a word of caution before playing with most of these - you can screw up things if you're not too careful, I guess it's good you're asking, however.
Old Aug 24, 2009 | 09:35 PM
Jackmup's Avatar
What is it your trying to do? Why not tell us that. You may have well just shown us a picture of a nut and said where does it go.
Some values you will not be allowed to change via vag-com some will only let you change them by a minor percentage. Seems like you are trying to do mods with the vag-com and it is really intended for diagnostics.
download a copy of Bosch uni settings it will allow you to make a few tweaks. But by the looks of it your headed the wrong way down a dark alley.
Old Aug 25, 2009 | 03:20 AM
xewax's Avatar
Member
When I press a button on my dashboard I can see "Service in 15000 kilometers". But after using my car for lets say 200 kilometers the value is still the same 15000 km. I know that this value should decrease until it reaches zero right? help me to do that. I think there is nothing special here by changing date or km, I won't change other values I just want to reset "service in ....kilometers". Any help to make it working?
Old Aug 25, 2009 | 11:30 PM
Jackmup's Avatar
Sorry my car doesn't have a service indicator. Repost that question someone knows how to reset that thing. Try to PM Auditech79
Old Aug 26, 2009 | 12:22 AM
auditech79's Avatar
Old Aug 26, 2009 | 12:25 AM
auditech79's Avatar
And this is the adaption procedure for changing the mileage.
Select 17-Instruments
Select Adaptation (10) under advanced functions
Enter Adaptation Channel Number: 42 and select "Read"
The window should read: "Minimum value mileage" and Min. Value Oil in 100 Miles
The stored value should read "50" for 5000 mile intervals
Enter "100" for 10000 mile intervals
Select "Save" and select "Yes" when VAG-COM asks "Are you SURE?"
Old Aug 26, 2009 | 12:31 AM
auditech79's Avatar
I just remembered that you may have to change the service intervals days from 180 to 365 days. To do this follow this procedure.
Enter Adaptation Channel Number: 49 and select "Read"
The window should read: "minimum time interval" and Min. Value Insp. in 1 Days
The stored value may read "180", if it does continue
Enter "365" for 365 days
Old Aug 26, 2009 | 02:48 AM
xewax's Avatar
Member
I will try and let you know about that. I hope I will do it successfully.
Old Aug 31, 2009 | 10:30 AM
xewax's Avatar
Member
Do i need to count and store days from inspection? Or just leave 0.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
