short to ground codes
Old Apr 2, 2015 | 07:53 PM
sandman7's Avatar
Default short to ground codes
Hello..
recently installed new battery and had it coded by local indy shop.
Mechanic handed me a printout from his vcds scan..car will start up and run great one day and other days it sounds like it's goin to shake itself to death...I have checked all the fuses under windshield cowl on drivers side. Can't seem to pull the two 614 relays out too check them..
is there a trick or are they just stuck?
The codes are as follows:
P1573, P2401, P0031, P0051, P1117, P1121, P1067, P 200 and PA 295
All are short to ground codes except p 157 which is open circuit.
I hope someone has some kind of idea..could these be codes that are stored in the ecu ???
Thanks in advance for your time
2007 a6 3.2 quattro 112k miles
Old Dec 30, 2018 | 09:21 PM
Abhishek Anant's Avatar
Originally Posted by sandman7
Hello..
Hi , were you able to solve the problem , I have exactly the same problem witht the same codes , I have a 2007 Audi a6 3.2 quattro's
StuHallA6Sline
Oct 23, 2016 02:28 PM
cl_n
Sep 30, 2013 05:43 PM
rhemy1
Dec 14, 2012 01:04 PM
Mya4T
Sep 9, 2007 09:10 PM
onepoint8tee
Nov 16, 2005 01:55 PM
