Should I go Lower?
Old Aug 13, 2006 | 08:29 PM
RadRup's Avatar
Default Should I go Lower?
This is my 2.8 98Q, i've had mixed opinions from friends about if i should go lower or let it be, what do you guys think?
[IMG]local://upfiles/19523/56EEA4EC5CA44EE7A3F09D345E2ADD60.jpg[/IMG]
Old Aug 13, 2006 | 09:35 PM
SouthboroAudiGuy's Avatar
Default RE: Should I go Lower?
I think it looks fine. Plenty of people out there will tell you to lower it to the point of dragging on the ground. Never understood it beyond a certain point. It looks great right now (don't YOU think?); lowering it will just give you a harsher ride. Save the money and put the dollars you saved into some great H-Sport anti sway bars. MUCH better to spend your dollars actually DOING something to improve the performance than just make the car look like a skateboard.
My $.02
Old Aug 14, 2006 | 03:58 AM
drj0ndurst's Avatar
that looks perfect to me, what suspension setup?
Old Aug 15, 2006 | 12:12 PM
slee22's Avatar
^^Agreed
Old Aug 15, 2006 | 02:19 PM
audiSean's Avatar
Don't do it.
You could make the car seem visually lower by adding some S6 or 4.2 door blades; they add visual weight to the bottom of the A6. Another alternative would be the RS6 skirts, though I'm unsure if they're available for a narrow body C5.
Old Aug 16, 2006 | 06:39 PM
norcalAudi's Avatar
That looks like about the same height as my stock 03 A6.
Old Aug 16, 2006 | 10:45 PM
03 A6 had the sport suspension (lowered by 20 mm relative to non-sport) as a STANDARD feature. Pre-03, it was a separate option. FWIW, the pic in my sig is an 01 sport suspension.
Old Aug 17, 2006 | 06:21 PM
Propagandalf's Avatar
Looks fine, your friends must be the type to put their money towards skid blocks rather than fixing their brakes....
MikeSpock/AWE
Apr 17, 2015 04:28 PM
Andrew/AWE
B8 Models
Feb 7, 2013 10:56 AM
Andrew/AWE
Feb 7, 2013 10:54 AM
cruciform
Oct 11, 2010 03:54 PM
wolfe2118
Jun 25, 2008 07:09 PM
