Should I hear the valves?
Old Sep 20, 2010 | 01:06 PM
ninetynineA6Q's Avatar
That's an easy fix. Just buy an old Dodge truck and you'll never run out of projects.
Old Sep 20, 2010 | 04:48 PM
oldmots's Avatar
Originally Posted by jhuffman
I run synthetic and I replaced the oil in the less then 500 miles ago at which time I did run some of that foam through the crank and drove through the mountains. As far as hearing sensitivity, I am very very sensitive to what sounds my car is making. I can't say that I am desperately worried about it, I've been over that engine 1000 times and everything is happy.
Maybe its just me being bored and wishing I had a car project. I call it automotive hypochondriasis... my honda turned out to be much less work than I was expecting (maybe hoping a tiny bit) and now I'm going crazy.
What do you mean by running foam through the crank? That strikes me as disturbing.
Old Sep 20, 2010 | 04:57 PM
nemohm's Avatar
Seafoam, one could guess- the ultimate solution for anything....
Old Sep 20, 2010 | 08:33 PM
jhuffman's Avatar
yes seafoam mate, as opposed to that instant structure foam that keeps the honda running. I do have an old back in the mountains. Its a 68 powerwagon. That is one of the most dependable trucks I've ever owned! It kept a battery for 20 years once!
Old Sep 21, 2010 | 09:32 AM
NH_USA's Avatar
OK huffy - It's time to get ear plugs or turn the radio up.
When cars get older it sometimes takes a few minutes for the lifters to pump up... It can be due to wear or sometimes crap getting stuck in the lifers or passages.
If you seafoamed you might have knocked a bunch of crap loose and big pieces could have started to plug the lifters.. like a clot causing a stroke. Hell I've seen people switch to high detergent oil and have that problem. In extreme cases the crap can plug up passages to the cam bearings and even the rod bearings but that is IN EXTREME CASES and seldom happens in new motors.
If the ticking is new change to oil and filter again and hope for the best - if it was there before you did the seafoam - the Audi is just getting old.
diggs
B7 Models
Aug 16, 2010 07:46 PM
soccergk
Mar 1, 2008 02:13 PM
XtremeR
Jun 15, 2007 01:47 PM
02TTs
May 24, 2006 03:59 PM
Joeski
Jan 3, 2006 07:40 PM
