signs of turbo failure?
My 00 2.7t 6psd makes some wierd noises upon driving right after start up. it sounds kind of like a police siren and almost like a slight grinding from the right side.. only does it for about a min or 2 and then stops. The slight police siren style whistle is pretty constant though.
How many miles does your car have on it? If it's more than 100k, it could easily be the turbo. Have you felt a loss in power?
Do some searching around on the A6 turbo issue; there is lots of commentary on options if you have a turbo that fails.
it has exactly 100k on it right now.. i bought it with 93 on and its mad the noises ever since. It also has misfired on occassion since i bought it. Dealer has tried to fix it 3 times and is wrong everytime. They gave me 2 new ignition modules, new egt sensor for bank 2 because the codes that come up are mis fires on 4 5 and 6. i just went out and checked the hoses.. if looking at the car from the front.. the left hose is dry and the right one by the oil filter has a little bit of stuff in it.. not enough to drip or pour out though.There was stuff by the house and surrounding parts. idk if its from oil from a oil change or something
