which size of brake rotors?
im looking to buy new rotors since ive shaved them down for the last time but i dont know what size to get since they come in 3 different sizes for an 01 a6 2.7t..16" wheel....4 pad front caliper....they come in 288..312..321mm? So how do i know which size to get?
You are gonna have the 321mm rotors on the front of that car. I got mine from this site. Check the linkhttp://www.germanpartsonline.com/catalog.html
this should help. It will show you how to check the build code.
Good luck
Good luck
you may or may not have the 321mm, check to make sure that you have the Lucas/Girling HP2 calipers. These calipers use an 8 pad set. Or 4 per caliper. If you do have the HP2 calip[ers then the 321mm are your rotor sizes. Some A6 2.7t came with the ATE brake system which had smaller rotors ( I believe the 312mm)
adamsrotors
Jun 25, 2015 02:32 PM
adamsrotors
Jun 25, 2015 02:31 PM
adamsrotors
Jun 25, 2015 02:15 PM
adamsrotors
Jun 25, 2015 02:10 PM
adamsrotors
Jun 25, 2015 02:07 PM
