Slight front end shake ..after adding new rims / tires
Old Feb 12, 2007 | 02:44 AM
rocdiggy's Avatar
Default Slight front end shake ..after adding new rims / tires
I have a 2000 A6 2.8 and recently just installed new 19" ADR M-Classic + 35 mm offset rims and 235/ 35/ 19 tires. When I drive over 60 miles per hour on the freeway there is a slight shaking / vibrations in my front end. I have heard that installing a donut (placed between the hub and the rim) may help with the shaking / vibration. Does anyone have any suggestions?
Old Feb 12, 2007 | 12:32 PM
CamoA6's Avatar
Default RE: Slight front end shake ..after adding new rims / tires
there is always realigning and re balencing.
Old Feb 12, 2007 | 01:32 PM
SouthboroAudiGuy's Avatar
Follow the link in my signature to my registry page. Click on 'Stoney's Links' and do a search for "Hunter Roadforce". Go to the Hunter site and use their dealer locator to find a Hunter Roadforce balancing system equipped garage near you. Have all four wheels balanced.
Report back if you still have problems. This simple step has resolved LOTS of problems for people in the past.
Old Feb 15, 2007 | 04:47 PM
rocdiggy's Avatar
Thanks! I re balanced on a hunter machine and added the hub centric ring and the my a6 rides smooth again
Old Feb 15, 2007 | 05:25 PM
Glad it worked out. Seems to do the trick just about every time.
Old Feb 20, 2007 | 12:35 AM
Bora's Avatar
for future refference if your steering wheel is still shaking slightly it might be your rear rotors, that was an issue i had in my 2000 a6 4.2 a little while back
Old Feb 20, 2007 | 03:09 AM
leighsean's Avatar
I run 19's and one of the keys to properly balancing the wheels is to make sure they balance the inside as well as the outside, Example. weights as close to the spokes as possible from the inside and weights on the outside lip, back of wheel (side you dont see) This method of balancing along with the use of hub rings is about the smoothest youll get when running BIG WHEELS! hope this helps.
bigpapascott
Sep 24, 2014 11:13 AM
jzstuggie
Jul 14, 2013 09:41 PM
M3Armand
Mar 19, 2013 10:51 AM
workoncars
Sep 19, 2011 11:07 AM
IPStevieB
Jul 29, 2011 12:28 PM
