Something got loose after replacing rear shocks
^^ Thats should be ok to do and is what I always do.. I dunno man. Looking at you rear suspension, I dont really see where you could have run into trouble unless you didnt tighten while having the full wieght of the car on the jack or NOT turning that extra 1/4 turn. There are a couple of things to look for though, such as the upper pins facing inwards:
TORQUE SPECIFICATIONS
Application....................................... ............................Ft. Lbs. (N.m)
(2) Tighten to specification plus 1/4 turn.
STRUT ASSEMBLY
NOTE: Check wheel alignment after servicing.
Removal
Raise and support vehicle. Remove caliper bolts. Remove stabilizer bar bracket at body. See Fig. 1 . Remove stabilizer bar upper link bolt. Remove upper control arm-to-wheel bearing housing bolt. Remove upper strut assembly bolts. Remove strut-to-lower control arm bolt. Push wheel bearing housing down and remove strut assembly.
Disassembly
Put strut assembly in tool. See Fig. 6 . Using spring compressor, compress strut spring until upper spring mount is free. Remove upper nut. Remove mounting bracket and damper ring. Remove spring compressor and spring.
Fig. 6: Compressing Strut Spring
Courtesy of AUDI OF AMERICA, INC.
Reassembly
To install, reverse disassembly procedure. Ensure spring ends are against rubber stops. Use NEW shock rod nut. Tighten fasteners to specification. See TORQUE SPECIFICATIONS . Remove strut assembly from tool.
Installation
To install, reverse removal procedure. Ensure pins on upper strut mount are toward outside of vehicle. Use NEW control arm and lower strut assembly bolts and nuts. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal
Disassembly
Reassembly
Installation
- Brake Caliper Bolts (1) ..............................................22 (30)
- Driveshaft-To-Differential Bolts ...................................41 (55)
- Lower Control Arm-To-Wheel Bearing Housing Bolt (1) .....70 (95)
- Lower Control Arm Inner Bushing Bolts (1) (2) ................52 (70)
- Splash Shield Bolts .................................................. ..7 (10)
- Outer Drive Axle Bolt (1) (2) .......................................85 (115)
- Strut Assembly-To-Lower Control Arm Bolt (1) (2) ..........52 (70)
- Strut Bracket-To-Body Bolt ........................................33 (45)
- Strut Bracket-To-Strut Assembly Nut (1) ......................20 (27)
- Subframe Bolts (1) (2) ..............................................81 (110)
- Sway Bar Bracket Nut (1) ...........................................15 (20)
- Sway Bar Link-To-Sway Bar Nut (1) ..............................37 (50)
- Sway Bar Link-To-Wheel Bearing Housing Bolt .................37 (50)
- Track Rod Inner End Nut (1) ........................................70 (95)
- Track Rod Outer End Nut (1) .......................................70 (95)
- Upper Control Arm Inner Bushing Bolts (1) ......................70 (95)
- Upper Control Arm-To-Wheel Bearing Housing Bolt (1) (2) ..52 (70)
After 3 months of hyatus I am looking again at solving this issue.
What I discovered this past weekend is the following:
Any thoughts?
- The car poor tracking was due to poor front tires inflation (the car sat for a while as I was driving my other vehicles)
- When I press each rear corner of the car there is no strange sound or behavior, however when the car rebounds I hear that dreaded CLUNK (on each side, independently)
- The springs are not broken, nor is the sway bar
- There is no evidence of anything else broken
Any thoughts?
Here are some information I found from the manual.
1. Spring ends, both top and bottom, must rest on the spring stops. Bottom stop should point to the middle of vehicle.
2. Bottom shock absorber bushing (the bottom bolt direction) must be parallel to the line created by the 2 upper mounting bolts.
One more reason to get a proper manual, not diy off the web...
2. Check!
And I do have that garbage Bentley DVD crappy manual I really really hate (please, ask me how I feel about it.
)I am still puzzled...
I have been doing some research on this since I am planning to do this soon. Anyways, one way that someone (I think it was midniteoyl) was to grind a side of the socket. Another was to use an O2 sensor wrench. I guess it is the same size.
