spark plugs changed, now wont start
RE: spark plugs changed, now wont start
you are correct, sir! that is what i meant, coils, not engine order. thanks for posting the diagrams. I have the bentley cd, but i havent seen those on it. do you have a different repair manual?
now down to your other problem which sounds like a vacuum issue
Vacuum connections
Vehicles without secondary air system (view from above)
1-
To vacuum unit for intake manifold change-over
2-
To vacuum reservoir
3-
To connection on intake manifold
4-
Non-return valve
5-
Intake manifold change-over valve -N156-
6-
Fuel pressure regulator to T-connection
7-
8-
Intake manifold
Engine (rear)
1-
2-
Suction-jet pump
3-
Non-return valve
4-
To vacuum reservoir
5-
Air intake connection
6-
Connection between air intake connection/throttle valve unit
7-
Connection between suction jet pump/air intake connection
Left side view
1-
2-
Suction-jet pump
3-
To brake servo
4-
To air conditioning system
5-
6-
Connection on throttle valve unit to activated charcoal filter solenoid valve1 -N80-
7-
Connection: suction-jet pump/intake manifold
Vehicles with secondary air system:
1-
Combination valve for secondary air (right-side)
q
On cylinder head (rear right)
2-
To activated charcoal filter solenoid valve1 -N80-
q
On air cleaner
3-
Throttle valve module -J338-
4-
Secondary air inlet valve -N112-
5-
Non-return valve
6-
7-
To brake servo
8-
To fuel system diagnostic pump -V144-
q
On USA models
9-
Combination valve for secondary air (left-side)
10-
11-
To vacuum reservoir
q
In front right wheel housing
12-
Intake manifold
13-
To actuator for intake manifold change-over
[IMG]local://upfiles/12092/EED0AD89F72E4198B1AA5F668D0F5B14.jpg[/IMG]
[IMG]local://upfiles/12092/DC19BA5703484414A1539F68EC7DB204.jpg[/IMG]
[IMG]local://upfiles/12092/94B08C06676C422E98EB6C8B7BD3B617.jpg[/IMG]
[IMG]local://upfiles/12092/0AFE55818CAF4E008866B5F019DF60C4.jpg[/IMG]
Vacuum connections
1-
2-
To vacuum reservoir
3-
4-
Non-return valve
5-
6-
7-
8-
Intake manifold
Engine (rear)
1-
2-
Suction-jet pump
3-
Non-return valve
4-
To vacuum reservoir
5-
6-
7-
Left side view
1-
2-
Suction-jet pump
3-
To brake servo
4-
5-
6-
7-
1-
q
2-
q
On air cleaner
3-
4-
5-
Non-return valve
6-
7-
To brake servo
8-
q
On USA models
9-
10-
11-
To vacuum reservoir
q
12-
Intake manifold
13-
