Squeaking Noise from front wheel
Old May 27, 2010 | 08:18 PM
nitrogen's Avatar
Default Squeaking Noise from front wheel
So...
I just came back from a week long vacation (car was not used) and when I got in my car i notice that there is a loud squeaking noise front the front left wheel when turning or going over bumps. This noise also happens when I push the front of the car down. I'm fairly positive that the shocks are going out (86k). (2003 a6 2.7T). If anyone has any experience with this then is it a good idea to replace springs as well? And how difficult is this process? (I've done a set of shocks and srpings on a Chrysler 300m and Honda Civic). Thanks for any input.
Old May 27, 2010 | 09:00 PM
NH_USA's Avatar
Shocks??
No try front struts.
As for the squeak- there a mess of links in the front that might have worn out bushings
Old May 27, 2010 | 09:06 PM
auditech79's Avatar
Upper control arm links to be exact. If you can hear the squeak when pushing down on the hood its always the upper control arms. You can buy a kit from www.ecstuning.com, and a plethora of other companies online.
Old May 28, 2010 | 08:12 PM
ninetynineA6Q's Avatar
If you spray the UCA bushings with PB Blaster every day for a week or two, it will at least quiet the creaking until you can replace the arms. I don't know about any of the other brands, but I had good luck with the febi/Bilstein kit from ECS Tuning. Take a look around the forum if you're going to do it yourself. There's a lot of great information. Good luck!
Old Apr 8, 2013 | 10:32 AM
wassiq's Avatar
Red face Driver's side front wheel squeeking
I recently collided into a parked car (it was heavily snowing!) and the bumper/headlight/bonnet were repaired on the driver's side. I have noticed a squeeky, grinding sound coming from the same side from the wheel. the mechanic assures me it is not connected to the accident but the wheel squeeks when turning the wheel and when going over bumps.
Could anyone advise?
Old Apr 8, 2013 | 12:36 PM
twopedalwarrior's Avatar
1) Don't hijack someone thread hoping to get an answer, open your own
2) Jack up your car and try turning the offending wheel(s), any sounds?
3) take your car to another mechanic for another opinion.
Old Apr 9, 2013 | 04:47 PM
wassiq's Avatar
Thanks for your reply. I actually tried to start a new thread but couldn't see anywhere how to do it. I appreciate your point, and more importantly, your suggestion re: the wheel squeak. My mechanic came to see the car yesterday and says its the steering rack, that it needs to be greased. Apparently the salt on the roads is causing this to happen to a fair few cars, especially those that have high mileage as it is.
bem1
B7 Models
May 7, 2014 08:42 PM
Paul h
Feb 18, 2014 01:28 PM
Dinesh Dave
Sep 6, 2012 07:22 PM
dqwnbe67
Apr 21, 2012 10:01 AM
smoovmusicdj
Feb 20, 2008 12:34 PM
