SRS Airbag light due to R/R Seat Belt
Old Apr 21, 2011 | 12:30 PM
dmillrod's Avatar
Default SRS Airbag light due to R/R Seat Belt
Hi,
I've got a 2000 A6 Avant with 145K that has an intermittent problem with the R/R Seat Belt sensor. It is triggered by my flipping the seat down and up again. My shop analyzed it once for $49 and said they found a 01212 code, which pointed to the R/R seat belt sensor.
I'm trying to avoid a medium-sized repair bill for a nuisance problem, so had a couple of questions:
- If I leave it alone and don't trigger it by flipping the seat, will the code clear on its own after awhile? If not, is there a way to clear it without specialized equipment (I only have an OBDII probe)?
- While the SRS light is on, if this was the only cause, will the airbag system still work properly?
Thanks!
Old Apr 23, 2011 | 11:43 AM
dmillrod's Avatar
Default results of some research I did
Thought I'd share the following in case it helps someone else in the future:
- Looks like their is a TSB about this code. Here is one archived thread:
http://forums.audiworld.com/archive/...t-2777796.html
TSB 69-06-05 says "Airbag warning light illuminates due to sporadic fault entry" and the solution is downloading new Airbag Control Module software.
- I'm a newbie and don't really know anything about VAG-COMs, but found a super low price software/cable ($36, no tax, no shipping) that I'm hoping can reset this DTC - we'll see:
http://www.gadgettown.com/Vagcom-VAG...USB-Cable.html
Since it only seems to trigger when I put the right rear seat down I may just reset it with this software when it triggers as the least-cost solution.
hazi2013
Jun 29, 2014 05:20 AM
Lion Heart
Sep 6, 2012 06:46 AM
larshenriksen68
Sep 20, 2010 02:53 AM
zenmaster358
Nov 29, 2007 12:42 AM
outasflyguy
Aug 17, 2007 07:56 PM
