Steering rack
My daughter just brought my 97 Avant back and there is a rubbing noise in the steering column. It sounds as if it is deep in the dash. The wheel turn smoothly but the noise is driving me nuts.
Has anyone else had this? What is the fix?
It may not be related but I have heard about problems with the rack bolts - How do you check them?
On my Volvo 850 (any car for that matter) there is a collar used as a ?bearing? between the passenger cabin and the engine bay. Volvo used plastic to make their collar and when it wore out would make a grinding/squeak sound. The only long-term solution was to change the collar, but on advice from others on the Volvo board, I used white lithium grease to shut it up. Worked for me. Now of course I have no idea if this is your problem but just an idea.
Jeff
Jeff
I found the answer. -
I noticed the squeek when I had the car on jack stands and was working on the brakes. Once I got it on the ground the squeek disappeared. One of the front tie rods was rubbing on the rubber boot on the fender well.
kobe24
May 1, 2009 12:17 PM
jetta8vwolfsburg
May 27, 2008 12:47 PM
