still cant find the problem
Old May 11, 2008 | 10:10 PM
LeAudi19's Avatar
Default still cant find the problem
i am getting so tired of this
had a misfire on cylender 2, and installed all 6 spark plugs
car ran fine..... noticed that the intifreeze box was cracking and leaked and replaced it i also had
a bad o2 censor on bank 1 and 2...... installed a universal one on both sides and it runs ok
the problem is it only runs good until i turn it off and then on again and the car is hot, the check engine still on and i dont know what i can do now
as i stated before everytime i press the accelerater m it feels sluggish and stuters from 15 to 40 miles...... if i press it hard, as someone told me the catylictics do a bang noise and the check engine blinks until i dont stepp on the accelerator and its just on
i noticed that it was leaking, im guessing oil under the 1,2,3 cilender box thing for the spark plugs near the o2 censor, but i cant reach or take a look at it
i am getting so anoyed and dont know what the heck might be the problem
anyone one have more suggestions??? if not i will be ready to take it to the dealer
thanks for any help and sorry for the long posts
Old May 12, 2008 | 10:56 AM
auditech79's Avatar
Default RE: still cant find the problem
Look behind the motor for the CTS (coolant temp sensor) if it has a black top change it.
They can cause the engine to run rich, which will foul O2 sensors, cause hard starting, and you guessed it, cause missfires.
You might also have a few vaccum leaks, so go over all your vaccum lines.
BTW, what engine do you have?
Old May 12, 2008 | 08:40 PM
LeAudi19's Avatar
i have a 2.8l 01 v6 engine
i had changed that beforem the water temp censor.......
what im talking about is on the actual box where the spark plugs are, i am 100 % sure that its oil, i used it today and i stepped on the gas a couple of times, and after im done alot of smoke comes from there
well, one thing is, what causes the engine light to blink many times? is it the vacum hoses??? leakage
Old May 12, 2008 | 08:47 PM
auditech79's Avatar
I have no idea what your talking about, post a pic if you can.
The check engine light flashing means its miss-firing and can cause catastrophic engine failure, SO STOP DRIVING IT!
It could be a bad coil or wire, try swapping the coils to the other bank and see if the miss-fire moves to the other side of the engine.
Old May 13, 2008 | 12:53 AM
LeAudi19's Avatar
thats a great idea!!!! i was thinking of buyin the deam ignition wires, but they still look good, man those guys from autozone must be sick of seeing me there almost everyday lmao!!
well ill record the smoke and post it on you tube then here, then u guys can see what im talking about
as for the missfire, thats the last thing i wanted to change was the ignition wires, but i guess ill have to now
flynnr
Mar 3, 2013 01:22 PM
evelluser
Dec 21, 2011 09:26 PM
aRIf
Jul 7, 2007 12:35 AM
Noobinator
Jun 13, 2007 07:33 PM
chebert69
Jun 12, 2006 02:18 AM
