STILL leaking!!!
Old Jun 18, 2009 | 10:24 AM
twinturbosixer's Avatar
Member
Post STILL leaking!!!
hey guys, I had my valve cover and cam adjuster seals replaced a month ago after i was told by both an audi dealership, and a performance shop that that was causing my oil leak... well, low and behold, theres something else leaking oil (in the rear of the engine).
any suggestions of things to check next? its an 01 a6 2.7t with 125K
Old Jun 18, 2009 | 11:04 AM
hxgaser's Avatar
Cam seals and plugs would be my next guess.
Old Jun 18, 2009 | 01:37 PM
gwos25's Avatar
[QUOTE= well, low and behold, theres something else leaking oil (in the rear of the engine).
any suggestions of things to check next? its an 01 a6 2.7t with 125K[/QUOTE]
As mentioned, it could be the cam seals/plugs. Also, did you service, clean or replace the PCV system? I've read that a dirty or plugged PCV system can contribute to leaking seals by allowing excess pressure to build up inside the engine. Newer models have an updated pcv spider hose assembly and a vented oil filler cap to help prevent this. My 01 2.7T has been getting worse lately, so I plan on doing all the mentioned seals very soon, as well as servicing the PCV system and replacing the oil cap with the newer version.
Regards.
Tirrany2000
Sep 2, 2008 08:26 PM
Jc61990
Aug 22, 2008 11:48 AM
darkminotaur
Jan 3, 2008 11:51 AM
Bryceaudi
Jul 31, 2007 03:42 AM
Dudek12
Jan 21, 2007 07:23 PM
