Sponsored by:
Sponsored by:
Strange Cold Weather Stalls 2000 A6 4.2 auto
Old 11-18-2014, 10:28 AM
mrjack11's Avatar
Default Strange Cold Weather Stalls 2000 A6 4.2 auto
Hi Everyone, appreciate you taking a look here, this is my first post on the forums. I'm having an issue with my 2000 A6 which I could really use help with. It's a 4.2 liter V8 Quattro with auto transmission. As far as I know it's had all scheduled maintenance and then some.
A few other similar threads have suggested cleaning different sensors to fix problems like this, if that's what you recommend could you pretty please include a link to a tutorial for me? I'm kind of a nub.
The Problem: Strange Cold Weather Stalls
-Starts up just fine
-Goes into gear fine
-Accelerates to end of driveway fine
-Sputters a bit as entering traffic
-Sputters and dies when decelerating at first stop
--(downshifting seems to be a major factor)
After a stop at convenience store, dies when backing out of parking spot while shifting from reverse back to drive.
Only other detail I can think of that might be relevant is that the power steering makes noise, sometimes, when it's really cold out. But I'm pretty sure that just needs to be flushed again.
Took it to a shop for this last year and they said it seemed fine even thought it shifted rough on me as I drove it out of their parking lot...
Old 11-18-2014, 04:41 PM
twopedalwarrior's Avatar
Codes Codes Codes, check for codes
Make sure you pull codes for the TCM, transmission control module
Old 11-18-2014, 04:50 PM
mrjack11's Avatar
Code readers...
http://goo.gl/JqUcBQ1
or
http://goo.gl/4sW2aW
Or is there a cheaper alternative?
I'll do my forum research on code readers tonight but I'm running to dinner. Sorry to be such a noob, thanks for sending me in the right direction.
Old 11-19-2014, 09:20 AM
links didn't work, just grab one of the ebay vagcom readers.
Old 11-19-2014, 04:11 PM
ppgoal's Avatar
Cheap answer may be add some gas line antifreeze. It's worth a buck just in case it is the problem.
tyfin85
12-03-2010 12:58 PM
luvin_the_rings
09-19-2006 09:50 PM
NDAudi
11-21-2004 11:38 PM
Quick Reply: Strange Cold Weather Stalls 2000 A6 4.2 auto
