Strong Gas Smell Inside
Old Feb 23, 2015 | 01:34 PM
rjdlyerb's Avatar
Question Strong Gas Smell Inside
I have a 2002 Audi A6, it has 145k miles
Not all the time but sometimes when it gets cold outside (meaning 20 or lower!)
When the car is started it smells strongly of gas inside.
When the car is moved, you can see a large puddle from underneath!
Any ideas as to where to start or what to fix?
Old Feb 23, 2015 | 11:06 PM
twopedalwarrior's Avatar
well if a gas puddle is underneath the car, that probably means gas is leaking from a fuel line. start simple and look at the fuel filter. chances are the fuel smell is coming back through the hvac because the fumes linger in cold air
Old Feb 25, 2015 | 11:22 PM
driftology's Avatar
Check the high pressure line under the hood. Mine was leaking at the line leading to to fuel regulator. Only on cold mornings.
Old Feb 26, 2015 | 05:00 PM
ppgoal's Avatar
In very cold weather, rubber will contract and it could be shrinking just enough to result in a leak under fuel pressure. A slight tightening of the fittings may help.
Leo-1st.b5
Oct 14, 2010 11:24 PM
dd1961
Jul 28, 2010 12:21 PM
c00lduke
Dec 26, 2009 03:08 AM
Firefighter6484
Dec 8, 2008 09:05 AM
austinpower
Jul 21, 2008 05:55 PM
