Sway bar questions
Will sway bars from a 2.7t fit a 4.2l? I was under the impression that the bars on all c5's are interchangeable but I just noticed that hotchkis has different part numbers for each. Thanks in adavance.
Well, there was a sport option for the 4.2, and I dont have it, so I was attempting to put on sport model sway bars which i would assume would be thicker. But the ones I have came off of a 2.7t. If noone knows I might have to get the car on a lift and compare.
Apparently, they are the same part number, so, logically, they should fit. There are two bars, Standard and Sport. The Sport bar won't fit the bushings of a Standard bar, but if you got the bushings with the bar, it should bolt up.
Bob
Bob
I don't know if you'll find what you're looking for, but you can look in the Febi catalog. Is worth a shot.
B5luver
Dec 18, 2007 12:42 AM
