Is Synthetic Power steering fluid ok?
Old Dec 26, 2008 | 07:05 PM
leftydog1961's Avatar
Default Experience is a great teacher
Since getting my A6 3.0 (quattro) AT used last year as a CPO, I have been periodically sucking and replacing the fluid in the resevoir with 11s using a turkey baster. The fluid was originally practically black, and 2 weeks ago was about medium dark green (the 11s is a nice lighter green color)...well low and behold, the pump started to moan and groan and the steering began to shimmy. I could feel it on cold days after 15 min rides, and it got progressively worse. Fortunately, I have the 100,000 mi plan, so I brought it to Audi and they replaced the pump. Took 1.5 hrs and cost me only 50 bux. I just opened the resevoir and the fluid is now almost clear with a slight pale green tinge. I suspect that they use 7.1 fluid.
Time to throw the 11s in the garbage.
do what you want but I will no longer be changing this fluid and certainly if it needs topping off, i will follow the advice printed on the resevoir plastic which says use only mineral based oil.
vtraudt
Mar 1, 2012 05:09 PM
jlballer
Aug 16, 2008 07:00 PM
audiS4jls
Apr 27, 2007 01:23 PM
thrax982
Mar 31, 2005 10:15 PM
