Tail light?
Old Dec 9, 2010 | 10:16 PM
SoDoWarts's Avatar
Default Tail light?
Is there a fuse connected to the rear tail light? The bulb went out but when I replaced it (a couple of times) it hasn't work. The Reverse and brake lights/bulbs are fine.
I'm wondering if there's a fuse that's not letting the bulb work. Thx
Old Dec 10, 2010 | 05:28 PM
ppgoal's Avatar
Generally there is a fuse for multiple lights, not just for the one tail light. The inside of the fuse cover (which should be on the end of the dashboard on the driver's side) should tell you what the fuses protect. If the other tail light is working, I doubt it is your fuse. I would suspect a short in the power or a bad ground.
pbrules10
Aug 2, 2011 01:22 AM
MagicHobo
Nov 14, 2008 01:37 AM
tsk
Apr 27, 2008 04:56 PM
audi ace
Jul 22, 2005 01:53 AM
