Tail light?
Is there a fuse connected to the rear tail light? The bulb went out but when I replaced it (a couple of times) it hasn't work. The Reverse and brake lights/bulbs are fine.
I'm wondering if there's a fuse that's not letting the bulb work. Thx
Generally there is a fuse for multiple lights, not just for the one tail light. The inside of the fuse cover (which should be on the end of the dashboard on the driver's side) should tell you what the fuses protect. If the other tail light is working, I doubt it is your fuse. I would suspect a short in the power or a bad ground.
crazybk187
Aug 5, 2013 04:29 PM
MagicHobo
Nov 14, 2008 01:37 AM
