Take Off problem Please Help !!
Old Oct 17, 2011 | 02:15 AM
Daniel917's Avatar
Default Take Off problem Please Help !!
i have a 2001 audi a6 2.8 automatic 130K if i stop at a light and take off it appears like it slips the gear and it jumps and studders .. i would have to take off little by little and it would go perfectly. a friend of mine told me it was the motor mounts since he braked and accelerated the car and he told me the motor lifts up badly please help me with this i hope its not a tranny problem. the car drives perfectly on the highway
Old Oct 17, 2011 | 10:13 AM
ppgoal's Avatar
Unfortunately, based on what you tell us, it sounds like transmission AND motor mounts. The "slipping" sounds like a the torque converter is going (or a clutch, if it was a manual) and it manifests itself under heavy load (accleration) rather than light load when cruising. Bad motor mounts would not cause slippage, but they could cause bangong as the motor moves around. If not corrected, that leads to worse problems. I suggest taking it to a reputable indie shop or even tranny place for a real diagnosis.
Old Oct 18, 2011 | 03:49 PM
altonachrome's Avatar
I had a similar issue which turned out to be a transmission mount. Good luck as it took them numeous hours just to loosen nut/bolt assembly at $92.00/hr.
Old Jan 24, 2014 | 11:00 AM
pascal munatsi's Avatar
eish guys I have the same problem if you take off slowly no problem but if you try to just speed off it jerks/slips then goes perfectly until the next stop, where is this mounting of the transmission
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
