Tech Inquiry
Old Sep 17, 2008 | 11:30 PM
Coors's Avatar
Question Tech Inquiry
Does anyone have a write up/walk-through for a vag-com headlight adjustment?
Will there be a code thrown if the headlight motors are malfunctioning?
I am awaiting my Vag cable and one of the things I would like to do first, is try to figure out why my headlights don't self level all the time. One points straight up, the other straight down. I suspect that the motors may be going or the gears may be getting stuck...yada yada yada.
I want to try this first before I take it into the dealership.
01 2.7T
Any input is greatly appreciated!
Thanks
E
Old Sep 17, 2008 | 11:50 PM
auditech79's Avatar
There would be a fault code in the headlight control module if the motors were bad or off alignment. To adjust them you would need to go into the headlight control module and use basic settings data block 1, the screen should tell you to wait for a moment then tell you to adjust the headlights. Once you are done adjusting the beam pattern move to basic settings data block 2, it should say that the positions have been learned.
Old Sep 17, 2008 | 11:54 PM
Coors's Avatar
Thank you, that is exactly what I was looking for. Good looking out!
I also found this
http://www.ross-tech.com/vag-com/car...alignment.html
Old Sep 17, 2008 | 11:56 PM
auditech79's Avatar
Yeah thats the same thing i told you more or less....
MED
B8 Models
Nov 8, 2011 10:43 PM
Red_Tiger
Sep 8, 2010 06:42 PM
cmacelo121
Sep 2, 2009 01:32 AM
TheDavey
Apr 1, 2009 12:52 AM
omastouris
Feb 15, 2007 11:55 PM
