Tempature Worry
Old Apr 10, 2008 | 12:24 PM
JcoyA6's Avatar
Default Tempature Worry
I have a A6 Quattro 98.... The tempature is almost always on "C" everyonce in a while is turns on and goes to the half way point. What is possible things I can check and do to fix this problem?
Old Apr 10, 2008 | 12:29 PM
Costner's Avatar
Default RE: Tempature Worry
Do a search for "coolant temperature sensor". You probably have a black one and it needs to be replaced.
Old Apr 10, 2008 | 12:42 PM
NH_USA's Avatar
It might be as simple as a bad connection.
Old Apr 10, 2008 | 01:34 PM
joetm's Avatar
i have the same problem on my 02 2.7 ... ECT is the problem i believe
Old Apr 10, 2008 | 02:18 PM
AZAudiA6Q's Avatar
Sounds like your temp guage is fault. Like it activates only once in a while due to a bad connection.
Old Apr 10, 2008 | 03:34 PM
joetm's Avatar
well i did some research and its only abad connection if it springs from "c" to the halfway point if its taking like 30 seconds to 2 mins to get from c to halfway then its either your sensor or your thermostat itself ... those are a pain in the neck to replace ... so unless its liek instantly jumping then ur screwed
good luck man
Old Apr 10, 2008 | 05:13 PM
formulagigi's Avatar
Audi will cover the Sensor for some models b/w 01 and 04 up to 100k miles.
Checdk with AOA, I got a letter from the, about an extended warranty on this 3 months ago
Old Apr 11, 2008 | 10:16 PM
joetm's Avatar
audi does not cover my car!
Old Apr 14, 2008 | 01:35 AM
screwed up!!! why??? isn't it b/w 01 and 04 model under 100k miles?
What was the reason if mien is covered?
Old Apr 14, 2008 | 04:10 PM
joetm's Avatar
2002 a6 2.7t s-line quattro with a lil over 70k on it ... yea makes no sense ... do u think AoA would just be trying to get out of it?
can you scan the letter and email it to me?
