Temperature issues with Audi a6 avant
Old Aug 6, 2010 | 02:49 PM
Jaynava's Avatar
Question Temperature issues with Audi a6 avant
Ok, here is the symptoms:
After a good while of driving the car if i stop and iddle for a bit, the temperature gauge starts rising, mostly with the A/C, ive noticed that if i dont have my A/C running the gauge wont rise that much. Then if i start driving again then the temperature starts going down.
Im thinking it can maybe be something related to the fan switch or maybe the temp sensor.
have any of you had any problems like this?
*sorry forgot to add the specs
its a 2000 Audi A6 Quattro Station Wagon, V6 2.8 30v
Old Aug 6, 2010 | 03:00 PM
nemohm's Avatar
It is typical behavior - problem => maybe not.
Look at the thread "Fan redundancy" - might find interesting to read.
BTW- read the sticky "nubie rules" first.
Old Aug 6, 2010 | 03:27 PM
Jaynava's Avatar
the thing that worries me is that the temperature guauge raises a bit to high.
i just bought the car so im not familiar with problems like this, even though i had a 1999 vw passat which basically has the same motor. but i never really experienced any problems like these.
The first step im taking is changing the Coolant because it does look like its very old. maybe that will help a bit.
Old Aug 6, 2010 | 05:52 PM
nemohm's Avatar
You're perhaps wasting your money
G12 - for life
Old Aug 6, 2010 | 06:33 PM
hxgaser's Avatar
Water temperature should stay right dead center of the gauge. If it is going above, then you have some cooling system issue. Start by flushing out the radiator and replacing with fresh G12 and distilled water.
If the temperature fluctuates below the center point, then you have a stuck thermostat issue.
It also could be that the secondary fan is not kicking in.
Old Aug 6, 2010 | 07:17 PM
upallnight's Avatar
You could also have a water pump on its way out. Do you have any prior service records for the car? When was the timing belt and water pump last replaced?
Old Aug 6, 2010 | 10:37 PM
Jackmup's Avatar
I second that.
Your engine is working harder with A/C on.
It is not getting enough circulation. Pump, Timing belt, Thermostat.
Old Aug 7, 2010 | 07:39 AM
bob martin's Avatar
It's not your water pump, it's your fan. Or, one of them. You are not getting enough air past the radiator.
Good luck,
Bob
Old Aug 9, 2010 | 08:33 PM
NH_USA's Avatar
YA YA Bob has it --- I'd bet that one or both of your fans are not comming on.
Nebuchadnezzar
Oct 24, 2017 03:40 AM
ShadowsmithA6
Jan 4, 2011 07:34 AM
slimty360
Dec 14, 2010 06:57 PM
bbboy
Dec 31, 2009 01:56 AM
DkJames
Jun 2, 2009 12:27 AM
