Throttle Problem / Engine code
Old Jul 2, 2008 | 11:58 AM
FixOrRepairDaily's Avatar
Default Throttle Problem / Engine code
99 A6 Avant - 2.85V engine - engine light comes on and the car hesitates and stalls, boggs down during acceleration like it is flooding or it has a fast idles. Next day i start it and it may be fine. Could it be a sensor, throttle body??? Why does it only happen when one day, then no check engine light or problems the next?? The following codes are comming on:
DTC
P-code
Description
17953
P1545
Throttle Pos.Contr Malfunction
17952
P1544
Throttle Actuation Potentiometer Signal too High
16507
P0123
Throttle/Pedal Pos.Sensor A Circ High Input
17973
P1565
Idle Speed Control Throttle Position lower limit not attained
16541
P0157
O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
Old Jul 2, 2008 | 12:46 PM
NH_USA's Avatar
Default RE: Throttle Problem / Engine code
Sounds like a bad TPS but clear the coades and see what returns
Old Jul 2, 2008 | 03:23 PM
99 A6 Avant - 2.85V engine - Can i just get the TPS sensor? called ECS tuning, and they said I have to get the whole throttle body? http://www.ecstuning.com/stage/edpd/...ategory=Engine
Also, is their another source for Audi parts you know of??
Old Jul 3, 2008 | 11:49 AM
NH_USA's Avatar
Call Chris semple at Force Five in Concord NH - 603-223-6700 he sells new and used Audi stuff. he dosen't like to diagnose but he is willing to give you buying options...
Old Jul 16, 2008 | 04:13 AM
jkyards's Avatar
Default Audi used dodge engine by texas junkyards
If you want a good selection id try a parts locator. One place that can find you a good short or long block for a Audi A4 used dodge engine is TEXAS Junkyards, Junk Yards in TEXAS TX salvage recycler. They have a link somehow to multiples of thousands of recycling centers and will locate the best one for you.
ysabraham
Oct 9, 2013 10:59 PM
vtraudt
Mar 9, 2012 07:03 AM
twinturbosixer
May 6, 2009 07:09 PM
707782y
Mar 7, 2006 09:21 AM
