Sponsored by:
Sponsored by:
Timing belt broke! :(
Old 11-25-2008, 02:25 PM
the G man's Avatar
hurricane860, how many miles you have on your Audi?
Old 11-26-2008, 10:07 AM
bob martin's Avatar
HUrricane860,
If the timing belt broke before the engine started, there is a chance that the valves are not bent. You'll need to run a leak down check on each cylinder to find out.
Good luck,
Bob
Old 11-29-2008, 09:37 PM
RedShoeRider's Avatar
You *may* have gotten lucky and not lunched any valves. As was said before, the fact that it wasn't running doesn't matter, as the starter has more than enough torque to bend valves up nicely. On startup is one of the more likely times that a belt will snap, as it's under a bunch of strain getting both camshafts and the pump spun up to speed while everything is cold.
Pull the heads and have a look. If you got lucky, you just have to do the timing belt (and everything else in there, too! Timing belt, water pump, thermostat, idler pulley, tensioner pulley, and the tensioner itself if you're so inclined). Just doing the belt is still asking for trouble later on down the road.
-Red
Old 11-30-2008, 11:03 AM
NH_USA's Avatar
Same as RedshoeReider.. Damage very likely - If you turned to motor over with the starter and had a broken TB there is a 98.7856% chance of bent vlaves.
Old 11-30-2008, 10:01 PM
hurricane860's Avatar
wow looks to me i got lucky not only did my timing belt NOT break it was just the camshaft sensor. which made it seem like it was exactly the timing belt but wasnt..thank god. but im changing my timing belt anyways for precautions
Old 12-01-2008, 12:14 AM
Jeffla's Avatar
That's great news.
Old 12-01-2008, 12:27 PM
NH_USA's Avatar
do the water pump and t-stat while your in there... The Blauparts kit has everything you need to do it correctly
  #18
Old 12-01-2008, 04:11 PM
zippy_gg's Avatar
You must be so relieved!!! That is good news indeed!
  #19
Old 12-08-2008, 07:01 PM
AR15Texan's Avatar
Looks like a better kit than the ecstuning and for less money. They even have a tool rental kit for $35 with $325 deposit.
dmount76
01-28-2013 07:56 AM
Crowss
03-28-2012 09:35 AM
fruitcakesa
12-21-2011 09:31 PM
vtraudt
04-01-2011 09:40 AM
DomsA4
06-09-2008 11:14 PM
Quick Reply: Timing belt broke! :(
