timing belt & water pump replacement any help ?
Old Jul 2, 2011 | 11:50 AM
audiaa6.2000's Avatar
Default timing belt & water pump replacement any help ?
I have a 2000 a6 2.7 turbo love the car miles is 190000 run great but I have no idea when the timing belt or water was change I would like to change it has anyone ever change there how hard is it to do I am very mechanical any special tools I need to have ? How
long is the job any help would be great thanks .
Old Jul 2, 2011 | 02:40 PM
FonzoB5S4's Avatar
its a bitch of a job. you need to either drop the engine or take the front of the car off. you can actually swing the front end over by only disconnecting one side. then you dont have to disconnect the a/c.
here is the kit i used:
http://www.ecstuning.com/Audi-B5_S4-...g_Belt/ES7439/
Old Jul 2, 2011 | 02:45 PM
02A6Beau's Avatar
I recommend taking the front off, it makes everything much easier that way. If you are mechanical minded you shouldn't have any trouble with the job. there are a lot of pretty decent walkthroughs out there, just study up on the procedure ahead of time. Nothing is really difficult per se, just a PITA to do all the labor required just to get to the point where you can get at the timing belt and components. Make sure you evaluate everything that you might want to change while you are in there because it is definitely not the kind of job that you will want to do again anytime soon.
good luck and keep us updated. remember if you run into any snags or have questions we are here to help you
Old Jul 2, 2011 | 02:56 PM
FonzoB5S4's Avatar
heres a diy on an allroad(basically the same thing as an a6):
http://www.audiworld.com/tech/eng.html
FonzoB5S4's Avatar
Old Jul 2, 2011 | 04:33 PM
sheldon's Avatar
I did mine on the 2002 4.2 at 82k (2.5 years ago) and it was a huge PITA as everyone states in here.
I took the entire front off, had access to plenty of tools and a lift. Since this was my first time it took me roughly 10h for the entire job. I'm sure there are peeps out there that can do it in less but I doubt you really want to set a world record on an important job like this one
Better safe then sorry.
Old Jul 7, 2011 | 10:40 AM
cudafish's Avatar
I replaced my 2004 2.7 timing belt. I was not that bad of a job. There were two things which I had trouble with. Both were no where to be found in the Bently manual. One was a water pump bolt only assessable through a small hole in water pump pully then turning pulley to line up hole with the bolt behind it. Very hard to see. The second was having to remove the left engine mount to gain acccess to remove crank shaft plug to install crank alignment pin. Good Luck
Old Jul 7, 2011 | 12:03 PM
hxgaser's Avatar
If you do it, then get the proper tools. Cam lock bar, crank lock pin, and gear puller to pull the sprockets off the cam... Those 3 tools ARE required unless you want to do it over again.
Old Jul 12, 2011 | 07:57 PM
ppgoal's Avatar
Look to ECS Tuning or Blauparts for kits that include everything. Do the waterpump. t-stat, and all tensioners. The shop hours are 6 for the 2.7T, but they have experience and training. I'd search the forum for all the info you can before starting. There are helpful short cuts and problems to avoid.
Old Jul 21, 2011 | 02:06 PM
Thanks for the info I am gonna buy the repair manual and do some research on it before I start it sound like it be a project will keep you updated
mach1head
Jul 12, 2013 03:33 PM
Finservman
Jun 7, 2013 09:16 AM
sa9023
Nov 23, 2010 06:58 PM
brrman
Mar 10, 2009 02:40 PM
lewishw
Oct 11, 2005 07:32 PM
