Timing Belt without Water Pump
Old Mar 26, 2008 | 09:11 AM
katcoota's Avatar
Default RE: Timing Belt without Water Pump
ORIGINAL: ppgoal
It sounds like you know what you're doing, but make sure it is not the secondary cooling pump leaking (it happens a lot on the 2.7T; not sure if the 4.2 engine has one). I'd also check hoses and the radiator since you seem to have about 105k miles.
I couldn't find a secondary water pump. Must be a 2.7 specific thing. The only one I have is the one run by the motor and not an additional electric one.
Being a slow leak and inside the TB housing helps explain why I can't find anything on the hoses in terms of residue.
Untouchabl3
Feb 2, 2011 07:16 PM
Dj Spiel
Oct 9, 2007 09:08 PM
skatemerica155
Aug 31, 2007 11:46 AM
audigirl1982
Mar 29, 2007 02:08 PM
Fall0ut
Dec 20, 2006 07:15 AM
