Tiptronic???
Old Dec 22, 2007 | 10:21 PM
Retard Riot 686's Avatar
Default Tiptronic???
Okay so i have a 2.8 A6 with Tip when u shift with the Tip should u let off the gas then get back on it or just stay on the gas while u shift?
Old Dec 23, 2007 | 12:05 AM
frankinstyn's Avatar
Default RE: Tiptronic???
You can stay on the gas. The transmission knows what its doing. There are technically still clutch pads in there though. If you want to go easy on the thing just ease of the gas a little. I don't.
Old Dec 23, 2007 | 12:40 AM
Baskin 4.2l's Avatar
no need to lift the ECU starts to adjust timing on the shifts and the torque converter will hold or release as needed. you don't even need to shift the trans in tip mode if you don't want to. the car will automatically still pull the next gear when it hits the trans limit
Old Dec 23, 2007 | 09:25 AM
gkb's Avatar
gkb
Member
i gotta a6, 2.8 also, i was wondering if the tiptronic makes the car any faster, meaning acceleration
Old Dec 23, 2007 | 10:39 AM
Thanks guys and yeah accleration it does cause u can raise the RPMS higher than in "Drive" mode. So you will notice a small difference atleast i do!
rpilote
Nov 10, 2007 01:31 PM
balkranjit
Oct 18, 2007 11:22 PM
YFZFourFifty
Jul 25, 2005 01:56 AM
lara687
Feb 3, 2005 12:32 AM
memo
Jan 22, 2005 03:30 PM
