Tiptronic problem
Old Jan 26, 2009 | 02:31 AM
ramses's Avatar
Angry Tiptronic not funtioning correctly
Hi guys, I have a little issue with my tiptronic on my 03 4.2. When in tip mode sometimes when I try to change gears it doesn't want to do so. I have to move the shifter around a couple of times or put it back into drive and back into tip mode again to correct it. And again after awhile same thing over and over. Any suggestions. Oh, BTW this happened after I replaced the shifter **** on the transmission.
Old Jan 26, 2009 | 11:31 AM
nemohm's Avatar
What did you made to replace the shifter ****?
You have disturbed the well being of the tip shifter switch!
Reconfig-adjustment is needed (unless you are due for replacement).
Bentley has plenty of info - be cautious as there might be inaccurate data. (as always with Bentley)
abiv95
May 20, 2013 05:27 PM
kuven0107
Dec 9, 2011 05:40 AM
Dadan
B7 Models
Dec 6, 2011 04:30 PM
QuickQuattro
Jun 26, 2007 07:56 PM
bAyArEaTQ
Jan 24, 2007 09:25 PM
