tranny fluid?
Old Apr 7, 2007 | 08:25 PM
  #21
duburban's Avatar
Default RE: tranny fluid?
I have a 5sp manual with 163k. Don't really know when the last time the tranny fluid has been changed. Should i change it, or would this be the age in which the tranny shreds itself after?
Old Apr 7, 2007 | 10:50 PM
  #22
GIAudi's Avatar
Yes, read the entire post. ALL fluids should be changed. Make sure the shop doing the work understands to use the correct fluid. A great source is Blauparts.com, ecstuning.com, etc. While you are under there change the diff fluid as well.
Old Apr 8, 2007 | 11:53 AM
  #23
phil13's Avatar
ok this is great help for me. can i use a different fluid or should i use audi tranny fluid only?
Old Apr 8, 2007 | 12:29 PM
  #24
Kevin's Avatar
Audi fluid.
Old Apr 8, 2007 | 12:33 PM
  #25
phil13's Avatar
thanks. how much is it a qt? is it different then normal atf?
Old Apr 8, 2007 | 02:13 PM
  #26
SSn's Avatar
SSn
It's about 15$, and as far as different goes, I've not seen any other atf that is approved for the application. On older cars Mobil 1 is recommended. For the new ones it says audi atf only. The good thing is that for most differentials you can use regular 75W90 synthetic gear oil from your local store.
Old Apr 9, 2007 | 11:58 AM
  #27
smtcapecod's Avatar
I'm going Redline fluids throughout, using their recommendations. Worked well on all my prior vehicles including the Porsche, I see no reason to stick with factory fluid. To each his own though.
Old Apr 9, 2007 | 02:59 PM
  #28
2k S4's Avatar
ORIGINAL: smtcapecod
I feel the same way, my car is all Redline. So far the Trans has been happy.
Old Apr 9, 2007 | 04:31 PM
  #29
SSn's Avatar
SSn
Just as I figured out later, there are many ATF's approved for ZF transmissions. The cheapest ones will be Valvoline Mercon V, Quakes State Multi Vehicle and Castrol Multi Vehicle.
FtCA4
Dec 18, 2007 04:38 PM
audijunky_1
Nov 19, 2007 08:04 PM
nugger
Jun 11, 2007 12:54 AM
toyolla86
Sep 25, 2006 04:46 AM
