tranny help!
Old May 9, 2007 | 12:54 AM
aud99's Avatar
Default tranny help!
the first problem im having is the manumatic mode is not working
and the second problem im having is the car is having problem downshifting
and help would be gladly appreciated thanks
Old May 9, 2007 | 02:22 AM
SSn's Avatar
SSn
Default RE: tranny help!
Your auto does not shift by hand? Check the magnetic/ellectric mechanism under the shift lever panel.
About downshifting, replacing fluid - the first thing you can do. Also there is such thing called kickdown switch, might be deffective.
Go to Autozone and get your fault codes. Also having a bentley (not factory) repair manual might help
Old May 9, 2007 | 09:29 PM
aud99's Avatar
i went to advance to check the code and they said it was the maf sensor so im going to try to replace that thanks
Old May 9, 2007 | 09:32 PM
SSn's Avatar
SSn
clean it first, check it's connections. it's quiet expensive.
Nemick
Sep 11, 2012 05:33 PM
luxuryimports1
Jul 4, 2009 10:56 PM
thursdaysstrike
Jun 19, 2008 06:38 AM
brent07
Feb 5, 2006 06:14 PM
