Turn signal issues
Old Jan 16, 2006 | 05:26 PM
the fuel's Avatar
Default Turn signal issues
I'm having some issues with the turn signals, problem is, they don't work, at all. How ever, my hazards work fine. They at first would work if i held the turn signal switch down lightly, but not all the way down so it would click. Then after a while, even if i held it down lightly, or pushed it down as normal, they didn't blink, nor make the clicking sound it makes when you've pushed the switch down to make a turn. I've checked fuses, might be the relay switch?? But if so, why do hazards work?? Or it could be that the actual switch has become disconnected fron the steering column?? Any ideas?? Thanks
Old Jan 16, 2006 | 09:18 PM
neversummer's Avatar
Default RE: Turn signal issues
I take it you did not look through the forum cause there is a post on the first page with the solution for your problem. Next time make sure you look a little harder. But what you need to do to fix the problem is replace the hazard button. The hazard button is also the relay for the turn signals. It is about a five minute job that you can do yourself. The harzard button is only $35.00 from the dealership too. Good luck
Old Jan 18, 2006 | 12:17 PM
the fuel's Avatar
I saw it after i posted, my bad, thanks.
D_Riot
Jul 29, 2010 12:16 AM
Pihrana
Mar 15, 2010 01:47 PM
WhiTeA4nATL
Jan 26, 2007 09:21 PM
greybullit
Feb 28, 2006 08:14 PM
paliracer
Feb 21, 2005 03:15 PM
