Upgrading just the rear sway bar?
Old Jun 8, 2010 | 01:44 PM
Bklynrx7's Avatar
Arrow Upgrading just the rear sway bar?
OK, so I have confirmed that the sport model sway bars I have are actually thicker than my 4.2 stock bars. Now I am not sure if I should swap both or just the rear. On other cars I know a heavier rear sway bar helped reduce understeer which the A6 has plenty of, but I am just not sure if this will have any negative effect on a quattro car. Any ideas?.
Thanks in advance.
Old Aug 30, 2010 | 12:32 AM
mikeross's Avatar
Member
Adding a sway bar link kit would let you have that additional roll stiffness efficiently and also adjust the front to rear handling balance of the car..However, I am not sure if it would have any negative effects on a quattro.
Old Aug 30, 2010 | 05:36 PM
jhuffman's Avatar
on a car as heavy as the a6 it could only help. I am dying to upgrade my roll bars because the thing wallows like a hippo on the interstate. I would upgrade both of them if you can, improving the rear might make it handle weird because of chasis twist
Old Sep 1, 2010 | 08:10 AM
bob martin's Avatar
Upgrading the rear alone will reduce understeer at the risk of going into the more "entertaining" oversteer condition. Since you have both bars, the only investment is time so have at it and report your results!
Bob
Old Oct 4, 2010 | 08:18 PM
Plectrum's Avatar
what would happen if i had a stock a4 wagon and only put a rear sway bar on. if i couldnt afford both at the same time could i put one on before the other or should i just save up
sdkotlo
Jun 13, 2013 01:11 PM
96A4Owner
Mar 20, 2008 01:50 PM
Ad0
Feb 24, 2008 05:34 PM
B5luver
Dec 18, 2007 12:42 AM
audihere
Jul 19, 2005 04:26 AM
