vag com tricks for 99 A6 2.8
Um. You can change the encoding on the transmission to go from normal to 'sport' (recode from 00000 to 00010), if you search around you'll see a lot of other encodings that you can choose from but these are all just for later model transmissions - you only get these two options in your '99 A6. See some info here: http://forums.audiworld.com/showthread.php?p=14899294
You can change the encoding on the engine to go from a A6 2.8L response to the A4 2.8L response (change the last digit to a 1 instead of a 2, more here), some say this gives the car a little bit more response in the upper rpm range.
And you can change a BUNCH of stuff with the central locks, check it out here: http://www.audiworld.com/tech/elec36.shtml.
I think that's it though.
Interesting - I wasn't aware of coding options like this for the transmission. A friend of mine has an 01 A8L - you wouldn't know if there's a recode option for those cars would you, something more like maybe an S8 or a similar sport program? He loves the car but thinks the shifts are way too soft for his tastes.
Of course I think my car is down to about 180hp nowadays anyway haha.
