Velocity RS4 Replica Rims
Old Apr 14, 2008 | 12:55 AM
  #21
formulagigi's Avatar
Default RE: Velocity RS4 Replica Rims
ORIGINAL: ppgoal
I'm still very happy with the rims. The look great, especially when washed and waxed. The also appear to widen the car's stance a little bit because of the way they bow out from from the hub. I've never mounted an OEM rim and a Velocity on the same side, but the Velocities seem to move the tires out a little farther in the wheel wells.
That's probably b/c the offset os more aggressive (i.e. ET 35 Vs. ET 43 or 45 on OEM) and they are also most likely wider.
Old Apr 14, 2008 | 10:40 AM
  #22
turbo kraut's Avatar
Tech Guru
ORIGINAL: formulagigi
ORIGINAL: ppgoal
and because of this... if you have a sagging shock or something you might hear that one rubbing something and that could be the clank/thud/ping/noise you are hearing with the rs4 wheels, not oe wheels
Jucka11
Mar 16, 2009 02:24 PM
revolution337
Mar 12, 2009 06:15 PM
thedon28
Jun 26, 2008 12:06 PM
ouTTie914
Aug 14, 2006 06:07 PM
Andrewuvm
Feb 25, 2005 01:54 PM
