Warning Signs
Old Apr 24, 2006 | 08:54 AM
mazza1965's Avatar
Default Warning Signs
Hi folks
I've just bought my first Audi, an 8 yr old A6 2.4 automatic which is by far the most technological car I've owned. I had it serviced as soon as I bought it and I was told that the brakes would need replacing after another 5000 miles or so. One day since then I was driving when I got a jolt from the car and the ABS warning light was on the dash. I also got a brakes warning symbol as well as the engine oil pressure symbol and the engine seemed to go into some sort of "safe" mode. I pulled over as soon as I could and turned off the engine and started reading through the hand book. When I turned on the ignition to double check the symbols they had gone. I turned on the engine and the car ran normally. This has happened twice since. Is this symptomatic of a major problem because if it is I'd like to be aware before I take it to a proper Audi garage.
Any advice would be appriciated.
Thanks
Maz
Old Apr 24, 2006 | 10:53 AM
techbod's Avatar
Default RE: Warning Signs
its more symptomatic of a lose/bad connection on the wiring side but it will have logged whats termed as soft codes in the computer have the codes read
Old Apr 24, 2006 | 04:26 PM
skyman8's Avatar
Hi
This is excatly the same problem I have now and Audi after 2 weeks of trial and error - even changing the dashboard - now claim that it is the ABS module. The cost is £1080 + vat + labour charge - totalling £1800 !
My car is 1998 A6 Advant.
You can get the module cheaper and get a mechanic to fit it.
Peter
Old May 10, 2006 | 03:57 PM
mazza1965's Avatar
Hi Guys
I took the car in and had a diagnostic and I was told that it needed a new ABS Control Unit. At £1060.00 + VAT + Labour I thought I'd find a used one. The car is that age where they're getting written off after accidents etc but I'm having trouble finding one in the UK so I've got a friend in Germany looking and I'm trying breakers in the States.
Does anyone here know where I can find one or know someone I can contact. The part No is 8EO 614 111 G and it's for a 97 A6 2.4 Auto petrol. I have no problem paying shipping from oversee because it can't be that heavy. Can it?
Thanks
Mazza
Old May 10, 2006 | 07:43 PM
beefski's Avatar
You could try Shokan.com They are an audi only used & new parts supplier here in the USA, specifically in NY.
Old May 10, 2006 | 07:58 PM
techbod's Avatar
http://www.bba-reman.com/content.asp...mmonly_failing
£395 from BBS,
£1800 is he taking the P
Old May 13, 2006 | 12:56 AM
mpw2.7T's Avatar
Default Try www.ModuleMaster.com. Also, ECSTuning sells the module for $500
Don't know about shipping to UK, duties, etc.
Msnickbroderick
Feb 8, 2011 03:37 PM
Sidy
Apr 6, 2010 05:14 PM
chriscollins
Aug 9, 2006 04:16 AM
